6847 Discussions
Compile error - unknown identifier ippiNormdiff_L1_8u_C1R
yaddayadda22
First time IPP user. I'm getting the above compiler error when calling my first attempt at using IPP, ippiNormdiff_L1_8u_C1R. I've included 'ipp.h', and linked to all the stub lib files and libguide40.dll (although libs shouldn't matter for this - the compiler doesn't know the symbol, not the linker)
I'm fairly sure the environment is set up right because I can call the 'getlibraryversion', which spits back the appropriate info. Even if the format of arguments is wrong, I'm not getting those kinds of errors.
Any suggestions are appreciated.
Matt
yaddayadda22
Oops - never mind. 'D' was not capitalized. Sleep is helpful :)
Matt
Vladimir_Dudnik
You are welcome Matt :)
Vladimir
