Converting 16bit to 8bit image using LUT
Aris_Basic
What would be best sequence (or possibly single call)
to convert a 16bit image to a 8bit image (grayscale) by applying LUT ?
I only found LUT calls that will produce image of same depth as source.
Thx
Naveen_G_Intel
ippiConvert_ is a function to Converts image pixel values from one bit depth to another. I hope this function will address your issue. Please refer to manual to know more about supported values for mod.
Naveen Gv
matthieu_darbois
New Contributor III
ippiLUTPalette_16u8u_C1R can do exactly what you want
Matthieu
