Could not expand IPPIncludeDir variable
Daniel_D
I have a minor issue with the IPP package. Whenever I compile a project I get these warnings:
1>C:\\Program Files (x86)\\MSBuild\\Microsoft.Cpp\\v4.0\\Platforms\\x64\\PlatformToolsets\\Intel C++ Compiler XE 13.0\\ImportAfter\\Intel.Libs.IPP.Intel C++ Compiler XE 13.0.targets(18,5): warning : Could not expand IPPIncludeDir variable. The registry information may be incorrect.
1>C:\\Program Files (x86)\\MSBuild\\Microsoft.Cpp\\v4.0\\Platforms\\x64\\PlatformToolsets\\Intel C++ Compiler XE 13.0\\ImportAfter\\Intel.Libs.IPP.Intel C++ Compiler XE 13.0.targets(19,5): warning : Could not expand IPPLibDir variable. The registry information may be incorrect.
The project does not use any IPP function. I already reinstalled IPP but without any success.
Daniel
SergeyKostrov
Valued Contributor II
You could easilyfix the problem by creating these environment variables. I fixed a similar problem with
Intel C++ compiler by adding an environment variable, like:
[Visual Studio] -> Tools ->Options -> Project and Solutions -> VC++ Directories -> select 'Show Directories for' combobox -> add variable(s)
Take into account that you will need to re-start a Visual Studio.
