DCT in ipp_sample MPEG2 for Linux
estegano
I want to change the DCT coefficients from the encoder.
When I tray do
ippiQuantIntra_MPEG2_16s_C1I( block, pContext->Video[pContext->cvindex].QScale, 0, count);
for (c=0;c<65;c++) block=((block>>1)<<1)|1;
it's ok, but when I take off |1
for (c=0;c<65;c++) block=((block>>1)<<1);
I have the message
qtplayer: video/seq.c:1818: Macroblock_420_I_frame: Assertion `ret == 0' failed.
Aborted
What's happening? Am I in wrong position form encoder?
Vladimir_Dudnik
could you please specify what version of IPP do you use?
Vladimir
Vladimir_Dudnik
By the way,we cansee you use loop through 65 DCT coefficients, but actually they should be64 (or less).
for (c=0;c<65;c++)
The next, while count represents a number of nonzero coefficients, it should be modified accordingly,
i.e decremented when 1 changed to 0.
Vladimir
estegano
Ops! It was a big mistake. ;-)
Thank you.
I'm using l_ipp_ia32_itanium_p_4_1_2 and making some tests with l_ipp-sample-video_p_4.1.002
I have another question, perhaps an easy question.
I want access the DCT coefficients before quantization but ippiReconstructDCTBlockIntra_MPEG2_32s performs inverse quantization.
I'm testing in MPEG2-decode/video/seq.c
How can I do it?
Thank you in advance.
Fbio
Vladimir_Dudnik
Hi Fabio,
unfortunately we do not provide such function in IPP. It might be considered for implementation in the next versions. If you feel such functionality will be useful - please submit your feature request through technical support channel (premier.intel.com)
Vladimir
