6847 Discussions
Decoding overflow / failure in latest IPP JPEG code with attached image
johnt
Hi there,
The latest IPP JPEG code loads the following image incorrectly when using 1/8th size (JD_1_8):
http://www.jrmediacenter.com/DevZone/CustomApps/Temporary/Heroes_1b468487.jpg
The black area at the bottom of the image gets blown out to white (overflow?).
Please note that we're using IPP in a widely used, commercially shipping product, and this is the first image we've seen this on.
-John
johnt
Vladimir_Dudnik
Hi there,
-John
Hi John,
What version of IPP do you use and what JPEG codec (is that from JPEGView sample or UIC codecs?)
Vladimir
johnt
Hi John,
Vladimir
Hi Vladimir,
We were using IPP 5.3 (with some custom patches we worked out together to fix existing bugs).
Because of this problem,we updated to IPP 6.0.1:
w_ipp_ia32_p_6.0.1.070.exe
w_ipp-samples_p_6.0.0.127.zip
The JPEG code is from JPEGView.
Updating to 6.0.1 did not change the problem in any way.
John
Vladimir_Dudnik
Thanks for info, we were able to reproduce the issue. Please stay tuned, we will do our best to provide you fix.
Vladimir
johnt
Vladimir
Thanks Vladimir. We'll stand by for a fix.
John
Sergey_Ryadno
hiJohn.
Try to change in jpegdec.cpp definition ofDCT_QUANT_INV8x8To1x1LS macro from
#define DCT_QUANT_INV8x8To1x1LS(pMCUBuf, dst, qtbl)
int val = (Ipp8u)(((pMCUBuf[0] * qtbl[0]) >> 3) + 128);
dst[0] = (Ipp8u)(val > 255 ? 255 : (val < 0 ? 0 : val));
to this
int val = (((pMCUBuf[0] * qtbl[0]) >> 3) + 128);
johnt
Quoting - sryadno
hiJohn.
to this
Thank you very much. That does the trick.
Cheers,
John
