Deployment to Windows Azure
cgeorg
I'm working on an image processing service that uses OpenCV. I'd like to deploy it in Windows Azure. If I compile with IPP, will the performance primitives be able to run on Azure, and more importantly, will they still provide a performance boost?
Chris
levicki
Valued Contributor I
Chris,
That obviously depends on what kind of hardware the code will run so you have two options:
1. Register for a free trial and try it yourself
Or if you want a deterministic answer:
2. Ask Microsoft
In any case, don't forget to let us know your findings.
