Dicom ReadImageRLE bug with 16-bit
Thomas_Jensen1
I think there is a bug in the IPP samples (ipp-samples.8.0.0.005), dicom.cpp, function ReadImageRLE().
With 16-bit RLE-encoded data, the bug surfaces:
  if(precision  > 8)
    ippsSwapBytes_16u_I((Ipp16u*)decData, width * height);
    image.CopyFrom((Ipp16s*)decData, step, roi);    // BUG
  else
    image.CopyFrom(decData, step, roi);
The step parameter is wrong. It is a copy of image.Step(), and it should be the step of the decData buffer, which is width*2.
The bug presents itself with either scanline mismatches in the resulting image, or with an AV because of buffer overflow.
Also, possibly Ipp16u should be used in CopyFrom, since pixels are usually 16u. Otherwise, the Dicom tag Pixel Representation should be used to determine if the pixels are signed or not.
Suggestion:
    image.CopyFrom((Ipp16u*)decData, width*2, roi);
Sergey_K_Intel
Hi Thomas,
Many thanks for finding this. Unfortunately, it is impossible for us to update the samples, because we are stopping support of UIC/Picnic samples, due to changed priorities to GPU support mostly.
Sergey
Thomas_Jensen1
I have understood that samples are end-of-life, but I also posted about that in the sticky note.
Just curious!
