Dmip: remove node ? unlink ?
Oliver
I didn't find a way to remove a node froma graph, and to unlink two nodes.
Is it a planned feature, is it by design ?
Today I must rebuild the whole graph each time I want to make a small change (ie bypass a node).
Alternate question: is there a way to disable a node (ie inPlace processing will do nothing, and regular processing will copy the first source image input) ?
Oliver
Vladimir_Dudnik
Hi Oliver,
Why do you need unlink capability? Are you trying to implement dynamically (at run time)modified graph? Note, you will need to compile a graph after changes in its configuration.
There is no such capability in DMIP predefined nodes. I think you may implement this in your custom node.
Vladimir
Igor_B_Intel1
Hi, Oliver
Quoting - Oliver
Oliver
Do you mean to disable SrcNode from processing?
If yes, DMIP can sometimes to remove it. It behaviour depends (do copy or do nothing) on several factors:
1. image data pointer and step: if they are not aligned - DMIP creates small aligned buffer and copy-in data.
2. Source data consumers: filters after SrcNode need border values, If you don't prepare border yourself, DMIP will do it for you.
Igor
