Error decoding H.264 using fast CABAC decoding
Pascal_Binggeli
Hello
[EDIT: i'm sorry that no content was provided in the initial post - there must have a compatibility issue with IE9 RC.]
The problem I'm experiencing is that using a specific MP4 file containing a H.264 video stream, the H.264 video decoder generates an access violation. The MP4 file has been created using handbrake (and I guess x264 video encoder internally.)
While decoding the bitstream, the decoder incorrectly identfies the type of a macrobloc and access memory ouside the buffer allocated for the bitstream.
The error disapears after setting the symbol CABAC_MAGIC_BITS to 0 in the file umc_h264_bitstream.h.
I'm using the IPP 7.0.2 with corresponding IPP base classes.
Do you have any idea about this problem ? Do you need the video file for reproduction ?
Thanks for your time,
Pascal
PaulF_IntelCorp
Hello Pascal,
No details in your post. If you provide some details we might be able to help out.
Paul
Pascal_Binggeli
Sorry,
I've edited the original message.
Pascal
PaulF_IntelCorp
Hello Pascal,
The upcoming 7.0.4 release contains some fixes that may address the problem you are citing above. Please check it out to see if it resolves your issue. The release should appear within the next two weeks. If you are a registered user with an up-to-date license you'll receive an email announcing the release update.
Paul
