6838 Discussions
Error in planar YCbCr to RGB conversion on Gen11 CPU
Matt_B
I've encountered an error in the following functions:
  • ippiYCbCr420ToRGB_8u_P3C3R
  • ippiYCbCr422ToRGB_8u_P3C3R
I don't have access to a great variety of systems to test, but I do have Gen7 and Gen 8 which work fine and a Gen11 which does not. I discovered this issue with IPP version 2020.4.311. I upgraded to version 2021.5.3, and the problem remains.
Briefly, the output images from both functions executed on the Gen11 system contain distorted vertical banding.
The attached zip file contains a self-contained VisualStudio project (using IPP 2021.5.3) with sample input files, output files as generated on the problem system, and the Windows system information dump from the problem system.
Any ideas? I didn't find indication that anyone else has reported this so far.
-- Matt
Matt_B
By the way, the sample code also generates output using the following functions:
  • ippiYCbCr420ToBGR_8u_P3C3R
  • ippiYCbCr422ToBGR_8u_P3C3R
The output from both of these is good.
ShanmukhS_Intel
Hi Matt_B,
Thanks for posting on Intel Communities with issue details and project files.
We are working on your issue internally, We'll get back to you soon with an update.
Shanmukh.SS
Ruqiu_C_Intel
Hello Matt_B,
Thank you for your patience. We would like to let you know that the fixed is available in oneAPI 2023.1 which launched last week.
Ruqiu
