6847 Discussions
Error while loading shared libraries: libiomp5.so
ederman
First, please let me say that I've searched the knowledge base for the similar questions before posting this, and I couldn't find a solution.
I installed IPP 7.0.7.319_ia32 under Ubuntu 10.04 LTS Lucid. And I am using Eclipse to compile my code. I've added the library paths:
/opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32
/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32
/home/vavlab/Desktop/Ekber/Exa-tech/OpenCV-2.4.2/build/lib
to the "C/C++ Linker Libraries" path, and included the following libraries:
opencv_calib3d241d.lib
opencv_contrib241d.lib
opencv_core241d.lib
opencv_features2d241d.lib
opencv_flann241d.lib
opencv_gpu241d.lib
opencv_highgui241d.lib
opencv_imgproc241d.lib
opencv_legacy241d.lib
opencv_ml241d.lib
opencv_nonfree241d.lib
opencv_objdetect241d.lib
opencv_photo241d.lib
opencv_stitching241d.lib
opencv_ts241d.lib
opencv_video241d.lib
opencv_videostab241d.lib
ippac.lib
ippcc.lib
ippch.lib
ippcv.lib
ippdc.lib
ippdi.lib
ippi.lib
ippj.lib
ippm.lib
ippr.lib
ipps.lib
ippsc.lib
ippvc.lib
ippvm.lib
ippcore.lib
But while compiling, I get this error:
error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
I use Eclipse SDK 3.7.2 Indigo, and each and everytime I restart my computer, I have to do "source /opt/intel/composer_xe_2011_sp1.10.319/ipp/bin/ippvars.sh ia32" to get a response for "echo $IPPROOT".
I am quite new to ipp, so please help me solve this. Many thanks in advance.
Regards.
Gennady_F_Intel
you have to add the path to the libiomp5 libraries which is located into/opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32/
or just to source/opt/intel/composer_xe_2011_sp1.10.319/bin/compilervars.sh ia32
regards
ederman
Thanks for your answer.
I've already added that path, and mentioned in my thread. But it still doesn't work.
Any ideas?
Ying_H_Intel
Hi Ederman,
The libiomp5.so is from OpenMP threading library, from Intel Compiler. You should be right thathave the library 's path /opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32 specified in linked library path.
But i had some question about the library yourinclude:
ippac.lib
ippcc.lib
ippch.lib
ippcv.lib
ippdc.lib
ippdi.lib
ippi.lib
ippj.lib
ippm.lib
ippr.lib
ipps.lib
ippsc.lib
ippvc.lib
ippvm.lib
ippcore.lib
why they are suffix are *.lib, under /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32
should they be libippi.so or libippi.a?
Anyway, the error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory. looks be a run-time error, not compiling error.
So the solution still is to set right run -time environment: LD_LIBRARY_PATH. (not IPPROOT or set C/C++ Linker Libraries" path,which is for compiling phase).
Not sure how to doin Eclipse SDK.
Could you please try under command line to run your exe with command
> your exe
Or
>Export LD_LIBRARY_PATH=opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32:/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32
:$LD_LIBRARY_PATH
>your exe.
Ying
ederman
Hello Ying,
Thank you for your reply.
Actually, those libraries are ended with ".so" as you said, I wrote with ".lib" just wanted to indicate them as library names, anyway.
I tried your suggestion in the command line, but still get the same error. Seems like IPP is not working well under linux.
Any ideas?
TimP
Normal linux way is to use the LD_LIBRARY_PATH setting such as the compilervars script would give you. If you wish to have your own path for shared objects, you could place a symlink or actual copy of the .so there. Maybe that causes problems in choosing among updated versions.
Ying_H_Intel
Hi Ederman,
As we haven't your exe file, Could you please show some of command results to us
>ldd yourexe
>echo $LD_LIBRARY_PATH
Ying
ederman
Hi Ying,
I did it as you said, and the output of command "ldd myexe" is:
linux-gate.so.1 => (0x00aa0000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00d20000)
libopencv_calib3d.so.2.4 => /usr/local/lib/libopencv_calib3d.so.2.4 (0x00612000)
libopencv_contrib.so.2.4 => /usr/local/lib/libopencv_contrib.so.2.4 (0x00bfa000)
libopencv_core.so.2.4 => /usr/local/lib/libopencv_core.so.2.4 (0x00110000)
libopencv_features2d.so.2.4 => /usr/local/lib/libopencv_features2d.so.2.4 (0x0032c000)
libopencv_flann.so.2.4 => /usr/local/lib/libopencv_flann.so.2.4 (0x003c0000)
libopencv_gpu.so.2.4 => /usr/local/lib/libopencv_gpu.so.2.4 (0x00774000)
libopencv_highgui.so.2.4 => /usr/local/lib/libopencv_highgui.so.2.4 (0x00428000)
libopencv_imgproc.so.2.4 => /usr/local/lib/libopencv_imgproc.so.2.4 (0x007b4000)
libopencv_legacy.so.2.4 => /usr/local/lib/libopencv_legacy.so.2.4 (0x004af000)
libopencv_ml.so.2.4 => /usr/local/lib/libopencv_ml.so.2.4 (0x006bc000)
libopencv_nonfree.so.2.4 => /usr/local/lib/libopencv_nonfree.so.2.4 (0x005d9000)
libopencv_objdetect.so.2.4 => /usr/local/lib/libopencv_objdetect.so.2.4 (0x00a1c000)
libopencv_photo.so.2.4 => /usr/local/lib/libopencv_photo.so.2.4 (0x005f1000)
libopencv_stitching.so.2.4 => /usr/local/lib/libopencv_stitching.so.2.4 (0x00aa1000)
libopencv_ts.so.2.4 => /usr/local/lib/libopencv_ts.so.2.4 (0x00e16000)
libopencv_video.so.2.4 => /usr/local/lib/libopencv_video.so.2.4 (0x0073e000)
libopencv_videostab.so.2.4 => /usr/local/lib/libopencv_videostab.so.2.4 (0x00b0f000)
libiomp5.so => not found
libippac.so.7.0 => not found
libippcc.so.7.0 => not found
libippch.so.7.0 => not found
libippcv.so.7.0 => not found
libippdc.so.7.0 => not found
libippdi.so.7.0 => not found
libippi.so.7.0 => not found
libippj.so.7.0 => not found
libippm.so.7.0 => not found
libippr.so.7.0 => not found
libipps.so.7.0 => not found
libippsc.so.7.0 => not found
libippvc.so.7.0 => not found
libippvm.so.7.0 => not found
libippcore.so.7.0 => not found
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0x00b83000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00b46000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0x00eb3000)
/lib/ld-linux.so.2 (0x00b66000)
libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0x005fe000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0x00ba9000)
librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0x00602000)
libz.so.1 => /lib/libz.so.1 (0x00bc2000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00bd7000)
libpng12.so.0 => /lib/libpng12.so.0 (0x00cbb000)
libtiff.so.4 => /usr/lib/libtiff.so.4 (0x0e288000)
libgtk-x11-2.0.so.0 => /usr/lib/libgtk-x11-2.0.so.0 (0x02e28000)
libgdk-x11-2.0.so.0 => /usr/lib/libgdk-x11-2.0.so.0 (0x1e4b3000)
libatk-1.0.so.0 => /usr/lib/libatk-1.0.so.0 (0x00ce0000)
libgio-2.0.so.0 => /usr/lib/libgio-2.0.so.0 (0x1edcb000)
libpangoft2-1.0.so.0 => /usr/lib/libpangoft2-1.0.so.0 (0x0fb31000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/libgdk_pixbuf-2.0.so.0 (0x00cfc000)
libpangocairo-1.0.so.0 => /usr/lib/libpangocairo-1.0.so.0 (0x0c576000)
libcairo.so.2 => /usr/lib/libcairo.so.2 (0x0e576000)
libpango-1.0.so.0 => /usr/lib/libpango-1.0.so.0 (0x197b6000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x0144b000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x02863000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x077e8000)
libgmodule-2.0.so.0 => /usr/lib/libgmodule-2.0.so.0 (0x0060b000)
libgthread-2.0.so.0 => /usr/lib/libgthread-2.0.so.0 (0x00a99000)
libglib-2.0.so.0 => /lib/libglib-2.0.so.0 (0x04a86000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x12d98000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00d16000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0x1b043000)
libXi.so.6 => /usr/lib/libXi.so.6 (0x1fee7000)
libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0x1e213000)
libXcursor.so.1 => /usr/lib/libXcursor.so.1 (0x0f920000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x1a9a2000)
libXcomposite.so.1 => /usr/lib/libXcomposite.so.1 (0x11b2a000)
libXdamage.so.1 => /usr/lib/libXdamage.so.1 (0x0cf16000)
libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0x19648000)
libpcre.so.3 => /lib/libpcre.so.3 (0x1464e000)
libresolv.so.2 => /lib/tls/i686/cmov/libresolv.so.2 (0x0b6f5000)
libselinux.so.1 => /lib/libselinux.so.1 (0x19f56000)
libpixman-1.so.0 => /usr/lib/libpixman-1.so.0 (0x0f9db000)
libdirectfb-1.2.so.0 => /usr/lib/libdirectfb-1.2.so.0 (0x1c19e000)
libfusion-1.2.so.0 => /usr/lib/libfusion-1.2.so.0 (0x01224000)
libdirect-1.2.so.0 => /usr/lib/libdirect-1.2.so.0 (0x0600e000)
libxcb-render-util.so.0 => /usr/lib/libxcb-render-util.so.0 (0x1d25d000)
libxcb-render.so.0 => /usr/lib/libxcb-render.so.0 (0x05d12000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x01adf000)
libexpat.so.1 => /lib/libexpat.so.1 (0x1722b000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x0eeb3000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x1c7f0000)
And the output of "echo $LD_LIBRARY_PATH" is totally nothing, empty. Then I tried your previous answer as first do "export LD_LIBRARY_PATH=opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32:/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32:$LD_LIBRARY_PATH", and then the output of "echo $LD_LIBRARY_PATH" is this:
Then, I tried again "ldd yourexe", and the output is this:
linux-gate.so.1 => (0x00867000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00110000)
libopencv_calib3d.so.2.4 => /usr/local/lib/libopencv_calib3d.so.2.4 (0x00abb000)
libopencv_contrib.so.2.4 => /usr/local/lib/libopencv_contrib.so.2.4 (0x00d54000)
libopencv_core.so.2.4 => /usr/local/lib/libopencv_core.so.2.4 (0x00206000)
libopencv_features2d.so.2.4 => /usr/local/lib/libopencv_features2d.so.2.4 (0x00768000)
libopencv_flann.so.2.4 => /usr/local/lib/libopencv_flann.so.2.4 (0x00422000)
libopencv_gpu.so.2.4 => /usr/local/lib/libopencv_gpu.so.2.4 (0x0048a000)
libopencv_highgui.so.2.4 => /usr/local/lib/libopencv_highgui.so.2.4 (0x00664000)
libopencv_imgproc.so.2.4 => /usr/local/lib/libopencv_imgproc.so.2.4 (0x00e15000)
libopencv_legacy.so.2.4 => /usr/local/lib/libopencv_legacy.so.2.4 (0x004ca000)
libopencv_ml.so.2.4 => /usr/local/lib/libopencv_ml.so.2.4 (0x00868000)
libopencv_nonfree.so.2.4 => /usr/local/lib/libopencv_nonfree.so.2.4 (0x0095d000)
libopencv_objdetect.so.2.4 => /usr/local/lib/libopencv_objdetect.so.2.4 (0x006eb000)
libopencv_photo.so.2.4 => /usr/local/lib/libopencv_photo.so.2.4 (0x005f4000)
libopencv_stitching.so.2.4 => /usr/local/lib/libopencv_stitching.so.2.4 (0x008ea000)
libopencv_ts.so.2.4 => /usr/local/lib/libopencv_ts.so.2.4 (0x00975000)
libopencv_video.so.2.4 => /usr/local/lib/libopencv_video.so.2.4 (0x00c4d000)
libopencv_videostab.so.2.4 => /usr/local/lib/libopencv_videostab.so.2.4 (0x00601000)
libippac.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippac.so.7.0 (0x00638000)
libippcc.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippcc.so.7.0 (0x00641000)
libippch.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippch.so.7.0 (0x00654000)
libippcv.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippcv.so.7.0 (0x007fc000)
libippdc.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippdc.so.7.0 (0x00659000)
libippdi.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippdi.so.7.0 (0x00660000)
libippi.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippi.so.7.0 (0x00b65000)
libippj.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippj.so.7.0 (0x00c2b000)
libippm.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippm.so.7.0 (0x00815000)
libippr.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippr.so.7.0 (0x00830000)
libipps.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libipps.so.7.0 (0x00a12000)
libippsc.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippsc.so.7.0 (0x00834000)
libippvc.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippvc.so.7.0 (0x00846000)
libippvm.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippvm.so.7.0 (0x00aa5000)
libippcore.so.7.0 => /opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32/libippcore.so.7.0 (0x00a75000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0x00bd4000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00bfa000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0x0d46f000)
/lib/ld-linux.so.2 (0x00a58000)
libdl.so.2 => /lib/tls/i686/cmov/libdl.so.2 (0x0085c000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0x00a8c000)
librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0x00ab2000)
libz.so.1 => /lib/libz.so.1 (0x00c80000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00c95000)
libpng12.so.0 => /lib/libpng12.so.0 (0x00cb6000)
libtiff.so.4 => /usr/lib/libtiff.so.4 (0x00cdb000)
libgtk-x11-2.0.so.0 => /usr/lib/libgtk-x11-2.0.so.0 (0x0aa83000)
libgdk-x11-2.0.so.0 => /usr/lib/libgdk-x11-2.0.so.0 (0x1dd95000)
libatk-1.0.so.0 => /usr/lib/libatk-1.0.so.0 (0x00d36000)
libgio-2.0.so.0 => /usr/lib/libgio-2.0.so.0 (0x16f4b000)
libpangoft2-1.0.so.0 => /usr/lib/libpangoft2-1.0.so.0 (0x14b77000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/libgdk_pixbuf-2.0.so.0 (0x1a2ad000)
libpangocairo-1.0.so.0 => /usr/lib/libpangocairo-1.0.so.0 (0x00c19000)
libcairo.so.2 => /usr/lib/libcairo.so.2 (0x0d682000)
libpango-1.0.so.0 => /usr/lib/libpango-1.0.so.0 (0x0c0dd000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x157ac000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x09e35000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x11c96000)
libgmodule-2.0.so.0 => /usr/lib/libgmodule-2.0.so.0 (0x00860000)
libgthread-2.0.so.0 => /usr/lib/libgthread-2.0.so.0 (0x00a52000)
libglib-2.0.so.0 => /lib/libglib-2.0.so.0 (0x214f8000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00c3a000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x070d3000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0x00958000)
libXi.so.6 => /usr/lib/libXi.so.6 (0x1baed000)
libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0x06d33000)
libXcursor.so.1 => /usr/lib/libXcursor.so.1 (0x1f276000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x12f9b000)
libXcomposite.so.1 => /usr/lib/libXcomposite.so.1 (0x00c25000)
libXdamage.so.1 => /usr/lib/libXdamage.so.1 (0x17c2d000)
libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0x11bff000)
libpcre.so.3 => /lib/libpcre.so.3 (0x065fc000)
libresolv.so.2 => /lib/tls/i686/cmov/libresolv.so.2 (0x1a1d1000)
libselinux.so.1 => /lib/libselinux.so.1 (0x0b539000)
libpixman-1.so.0 => /usr/lib/libpixman-1.so.0 (0x1c5df000)
libdirectfb-1.2.so.0 => /usr/lib/libdirectfb-1.2.so.0 (0x08f07000)
libfusion-1.2.so.0 => /usr/lib/libfusion-1.2.so.0 (0x10897000)
libdirect-1.2.so.0 => /usr/lib/libdirect-1.2.so.0 (0x1da9f000)
libxcb-render-util.so.0 => /usr/lib/libxcb-render-util.so.0 (0x116d8000)
libxcb-render.so.0 => /usr/lib/libxcb-render.so.0 (0x0bb65000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x038d7000)
libexpat.so.1 => /lib/libexpat.so.1 (0x01cfd000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x01acf000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x1f265000)
Seems like it still couldn't find "libiomp5.so". Any ideas?
Regards.
Ying_H_Intel
Hi Ederman,
Could you please check ifthe libiomp5.so isin the path "opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32"?
or copy it to/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32
then see if it can be found.
Ying
ederman
Hi Ying,
libiomp5.so is in the path "opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/ia32".
Regards.
Ying_H_Intel
Hi ederman,
How aboutcopy it to/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/ia32
or could you please attached your exe to me and let me check?
Ying
ederman
Hi Ying,
Thank you for your answer.
Actually I spent so much time on it but couldn't solve it thnI installed windows to let it work. Now under windows, it works good.
Regards.
