FFT data manipulation
enricbosch2002
I would like to make a mask of FFT image to obtain information in some frequency bands.
The iplRealFft2D or ippiFFTFwd give me the coeficients of the FFT in the RCPack 2D mode. I don't know how to get a similar image matrix (352x288) with FFT fourier coeficients.
I would be very grateful if youcould help me.
Enric
Vladimir_Dudnik
Hi Enric,
You can use the following functons to data from RCPack format
Code:
//  Name:           ippiPackToCplxExtend
//  Purpose:        Converts an image in RCPack2D format to a complex data image.
//  Returns:
//      ippStsNoErr            No errors
//      ippStsNullPtrErr       pSrc == NULL, or pDst == NULL
//      ippStsStepErr          One of the step values is less zero or negative
//      ippStsSizeErr          The srcSize has a field with zero or negative value
//  Parameters:
//    pSrc        Pointer to the source image data (point to pixel (0,0))
//    srcSize     Size of the source image
//    srcStep     Step through  the source image
//    pDst        Pointer to the destination image
//    dstStep     Step through the destination image
//  Notes:
IPPAPI (IppStatus, ippiPackToCplxExtend_32s32sc_C1R, (const Ipp32s* pSrc,
        IppiSize srcSize, int srcStep,
        Ipp32sc* pDst, int dstStep ))
IPPAPI (IppStatus, ippiPackToCplxExtend_32f32fc_C1R, (const Ipp32f* pSrc,
        Ipp32fc* pDst, int dstStep ))
Vladimir
enricbosch2002
Thank you for the answer.
I have a sample image and I use some ipp, ipl and opencv fuctions to obtain theFFT coeficients.INTENTFFT_MAG_8.JPG is the result of FFT coeficients, but i don't know if it's correct .
The result of the FFT coeficients of a white image (352 x 288) is strange. It's the code correct ?
I want to otain an image that show me the frequency components, but I don't know if it's wrong or I don't know how to interpretate the result.
IplImage* SRC = cvLoadImage("INTENT_4.JPG",0); //Gray image
cvSaveImage("SRC.JPG",SRC);
IplImage* INTENT_GRAY32= cvCreateImage( cvGetSize(SRC),IPL_DEPTH_32F,1);
cvConvertScale(SRC,INTENT_GRAY32, 1 , 0 );
cvSaveImage("INTENT_FRAME_GRAY32.JPG",INTENT_GRAY32);
IppiSize INTENTSIZE = {INTENT_GRAY32->width,INTENT_GRAY32->height};
CvSize EXTEND ={2*SRC->width, 2*SRC->width};
IplImage* INTENTFFT=cvCreateImage(cvGetSize(SRC),IPL_DEPTH_32F,1);
IplImage* INTENTResult=cvCreateImage(cvGetSize(SRC),IPL_DEPTH_8U,1);
IplImage* INTENTIFFT=cvCreateImage(cvGetSize(SRC),IPL_DEPTH_32F,1);
iplRealFft2D(INTENT_GRAY32,INTENTFFT,IPL_FFT_Forw);
IplImage* INT_M=cvCreateImage(EXTEND,IPL_DEPTH_32F,1);
ippiPackToCplxExtend_32f32fc_C1R((Ipp32f*)INTENTFFT->imageData,
INTENTSIZE,INTENTFFT->width*
sizeof(Ipp32f),(Ipp32fc*)INT_M->imageData,
INT_M->width*
sizeof(Ipp32fc));
IplImage* INTENTFFT_8=cvCreateImage(cvGetSize(INT_M),IPL_DEPTH_8U,1);
cvConvert(INT_M,INTENTFFT_8);
cvSaveImage("INTENTFFT_8.JPG",INTENTFFT_8);
IplImage* INTENTFFT_MAG=cvCreateImage(cvGetSize(INT_M),IPL_DEPTH_32F,1);
IplImage* INTENTFFT_MAG_8=cvCreateImage(cvGetSize(INT_M),IPL_DEPTH_8U,1);
ippiMagnitudePack_32f_C1R((Ipp32f*)INTENTFFT->imageData,
INTENTFFT->width*
sizeof(Ipp32f), (Ipp32f*)INTENTFFT_MAG->imageData,
INTENTFFT_MAG->width*
sizeof(Ipp32f), INTENTSIZE);
cvConvert(INTENTFFT_MAG,INTENTFFT_MAG_8);
cvSaveImage("INTENTFFT_MAG_8.JPG",INTENTFFT_MAG_8);
andrewk88
Enric,
You may find the thread link below to be of interest
http://softwareforums.intel.com/ids/board/message?board.id=IPP&message.id=1156&query.id=5983#M1156
Andrew
