Face Detection Sample Code
arrahul
Hai
I am facing an issue while I am trying to run the Face detection sample code under the Intel IPP Image processing section. I am trying to run in the Microsoft Visual Studio 2010 env with Intel parallel studio intergrated in. I am having no build errors. But even If i have given the administrator privilege, the code is not executing. It is giving the following error:
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\ntdll.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\kernel32.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\KernelBase.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\mfc100d.dll', Symbols loaded.
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\msvcr100d.dll', Symbols loaded.
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\user32.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\gdi32.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\lpk.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\usp10.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\msvcrt.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\shlwapi.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\winsxs\\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7600.16661_none_a44e1fc257f685f6\\comctl32.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\advapi32.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\sechost.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\rpcrt4.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\msimg32.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ipps-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippcore-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\compiler\\libiomp5md.dll', Binary was not built with debug information.
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippi-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippcc-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippcv-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\imm32.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\msctf.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\uxtheme.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\dwmapi.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Windows\\System32\\mfc100enu.dll', Binary was not built with debug information.
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\mkl\\libimalloc.dll', Binary was not built with debug information.
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\1033\\ippmsg.dll', Binary was not built with debug information.
'Face_Detection.exe': Unloaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\1033\\ippmsg.dll'
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippsu8-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippiu8-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippccu8-7.0.dll', Cannot find or open the PDB file
'Face_Detection.exe': Loaded 'C:\\Program Files (x86)\\Intel\\ComposerXE-2011\\redist\\intel64\\ipp\\ippcvu8-7.0.dll', Cannot find or open the PDB file
CFile exception: fileNotFound, File test.bmp, OS error information = 2.
First-chance exception at 0x000007fefd5daa7d in Face_Detection.exe: Microsoft C++ exception: CFileException * __ptr64 at memory location 0x0013f468..
Detected memory leaks!
Dumping objects ->
{280} normal block at 0x00000000004ECA90, 48 bytes long.
Data: < ? > F0 DF F6 3F 01 00 00 00 00 00 00 00 00 00 00 00
{279} normal block at 0x00000000004EC9F0, 48 bytes long.
{278} normal block at 0x00000000004EC950, 48 bytes long.
{277} normal block at 0x00000000004EC8B0, 48 bytes long.
{276} normal block at 0x00000000004EC810, 48 bytes long.
{275} normal block at 0x00000000004EC770, 48 bytes long.
{274} normal block at 0x00000000004EC6D0, 48 bytes long.
{273} normal block at 0x00000000004EC630, 48 bytes long.
{272} normal block at 0x00000000004EC590, 48 bytes long.
Object dump complete.
The program '[4772] Face_Detection.exe: Native' has exited with code -1 (0xffffffff).
When I tried to debug the code, it is displaying as " Image file not readable". Could anyone give me a valid input image file for testing. I have been running into this issue for a long time. Please help.
Naveen_G_Intel
Give .bmp as input file, it should work.
Naveen Gv
arrahul
Hai
I have tried different bmp files. I will add the files that i have tested with. I have tried with couple of other .bmp files. Here I have attached two of them. Could you please send me any files with which you have tested it. Ordid you test itwith the file which comes as a part of the installation?
Rahul
Naveen_G_Intel
Hi Rahul,
I have used IPP (w_ipp-samples_p_7.0.4.054) face detection sample, input file as test.bmp which you sent. Result file is attached to this message.
Command to run face detection sample.
Naveen Gv
arrahul
Dear Naveen
Thanks for the support. I dint get the result file that you have sent. I tried this command line option in different cases. It is not giving a result. Still it is showing the same error. Is there anything like, I should set this command line option as a post build command line option.
Rahul AR
Naveen_G_Intel
Hi Rahul,
Errors are looks like not from IPP configuration, is it possible to verify it on any other system?
Naveen Gv
