Failure when building speech-coding examples.
pchapman
I was using IPP 4.1 to compile the speech coding samples, and I came across a few problems. I've now upgraded to the evaluation version of 5.0.
I use the batch files to build the speech-coding examples and it appears to compile okay - creating two executables and the library. When I try to execute I get the error: "Entry Point Not Found - The procedure entry point ippGetCpuClocks could not be located in the dynamic link library ippcore.dll"
I followed the FAQ's on setting up the environment variables etc.
I also tried building them in MSVC 2003, and the libray built sucessfully, and theapplication. When trying to execute the application the error:
"Entry Point Not Found - The procedure entry point ippGetCpuType could not be located in the dynamic link library ippcore.dll"
I'm using Intel C++ Compiler 9.0, IPP 5.0 Evaluation, XP Pro, MSVC.NET 2003.
Any help would be gratefully appreciated.
Paul.
Message Edited by [email protected] on 11-03-2005 02:11 AM
Vladimir_Dudnik
it looks like you have somewhere on your system old version of ippcore.dll, and this old version stay before the latest version.
Could you please double-check you you do not have IPP v4.0 in your PATH system variable, or in your windowssystem32 folder?
Vladimr
pchapman
Thank you, this seems to have resolved this problem.
Paul Chapman.
Vladimir_Dudnik
Ok, great.
