Frame loop of IPP H.264 Encoder
mdsaku
Hi Guys,
I am new in IPP H.264 and trying to using IPP 6.1.
Basically, I am trying to make two pass encoder. For example, at first, first 5 frames of the video will be encoded. Then based on the encoding result, again I will re-encode first frame.
As my understanding, I need to change a function which contain frame loop.
May I know the top most level function of the IPP H.264 Encoder, which encode all of the frames of video and has a frame loop?
I found a function Status H264ENC_MAKE_NAME(H264CoreEncoder_GetFrame). This function encode only one frame.
Does anybody can help me?
Sarwer
Ying_H_Intel
Hi Sarwer,
You may refer to the simpleencoder.cpp in the article and see if it can help.
Getting Started with Intel IPP Unified Media Classes Sample
Ying
