6838 Discussions
G729 Codec IPP 8.2 doesn't perform better than non IPP implementation
santosh_k_
we recently bought Intel® Parallel Studio XE 2015 which has IPP 8.2 version. we are using them with Intel samples for G729 speech codec. I tried using intel 8.0 samples and Intel 6.1 samples. Both of them are not giving better performance than our own implementation. we also have IPP of 6.1 version which is giving better performance than 8.2.
I linked 6.1 G729 samples with 6.1 version and 8.2 version of IPPs out of both 6.1 version gives better performance.
IPP 6.1 version linked with 6.1 version sample  avg per/frame encode time: 21 microsec
IPP 6.1 version linked with 8.2 version sample  avg per/frame encode time: 42 microsec
IPP 8.0 version linked with 8.2 version sample  avg per/frame encode time: 46 microsec
Current platform is:
OS: windriver (3.4.43-WR5.0.1.13_standard)
Hardware:  Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
Santosh kasula
Igor_A_Intel
Hi Santosh,
what do you mean under "8.2 version sample"? according to the sticky message at the top of the forum topics you can see that since 8.0 version IPP doesn't support umc samples and has moved them to legacy.
regards, Igor
Tang_C_
HI,Santosh
 I meet the same problem, when i use sample 7.0  g729 under ipp7.0, CPU 61%, but use  samples 8.0 under 8.2, CPU 77%
 in addition, by your testing,
but i test the encode time about 110 microsec per/frame, can you tell how to optimize option to compile the sample and application,thank you very much
 CPU model name    : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
