6847 Discussions
Getting ippStsRangeErr when calling ippsRSEncodeInit_8u
Noga_Tal
I'm using IPP 7.0 for Linux to do encoding with the Reed Solomon library.
When I set feBitSize = 3, there are no problems, and encoding works fine.
But when I set feBitSize = 8, I get:
ippStsRangeErr: Bad values of bounds: the lower bound is greater than the upper bound
when calling the function ippsRSEncodeInit_8u.
The generator polynomial is {1, 0, 1, 1, 1, 0, 0, 0, 1}
root = 1
codeLength = 7
dataLength = 5
Therefore:
256 = orderof(GF) > codeLength > dataLength.
Am I missing something?
Thanks!
Noga Tal.
Chao_Y_Intel
Please find some comment on some expert on this question:
The classic variant of RS code has the following parameters:
Block length (length of code word): n = q-1
Message length: k
Alphabet size q = 2^m
If the code has n<(q-1), actually it is some "shorted" RS codes. For such "short" code, IPP does not support.
Chao
Noga_Tal
Thank you for the quick answer!
Can you please refer me to the expert's comment?
I couldn't find it.
Noga.
