6847 Discussions
H.263 Decoding failure to decode UBC-TMN bitstream
Deleted_U_Intel
Question regarding:
Package ID: w_ipp-H263-decode_p_4.0.006
Package Contents: Intel IPP H.263 Decode Sample for Windows*
I tried to decode the H.263 bitstream generated by using UBC H.263+
encoder, which is used for the ITU-T H.263 standardization.
But the IPP decoder only produces the erroneous blocks.
I attach the h.263 bitstream.
With regards,
K.-Y.
Vladimir_Dudnik
Thank you for the report, we will check this. It would be better if you also submit this to technical support.
Vladimir
Vladimir_Dudnik
Hi, we found that there is bug in sample in part of decoding GOB headers. Sample will be corrected later. Thanks you.
Vladimir
