H.264 Decoder hangs on close
Christoph_Hansen
I currently have a problem after upgrading from IPP 7.0.4 to 7.0.7 and the related UMC samples. Now, the H.264 decoder hangs within the close routine. I know, that this should be fixed since 7.0.6 and therefor I'm a little bit confused.
I have tracked it down to vm_mutex_lock function in which the deadlock seems to be.
Do I have to take anything else int account? Any help would be appreciated.
Thanks in advance and regards,
Christoph
Christoph_Hansen
some additional information:
I could get around these problems by setting the thread numbers explicitly to 1 or 2 befor initiating the decoder. After this, close finished properly. The former initiation used 0 (as this is the default value) as threadNum value.
After all, is this a known issue or do I have to do anything different?
Christoph
