H.264 SD Decode Memory Leak
Atsushi_S_
Hello, I have serious trouble with Inte IPP.
I am developing Viewing Soft Ware of H.264 Video Stream Encoder.
For it, I use Intel IPP 8.0 Update 1 and w_ipp-sample_p_7.1.1.013.
And I build it with command "build.pl audio-video-codecs ia32, vc2008, d, st".
Then I tried to decode H.264 SD(720x480) with UMC::H264VideoDecoder.
Decoded Image is no problem, but memory leak happen.
So I resarched soft ware with Inspector XE where memory leak happen.
And It indicated thaht memory leak happen umc_h264_segment_store.cpp and umc_h264_task_supplier.cpp
SoftWare execute enviroment is
OS: Windows 7 Professional SP 1 (32bit)
CPU: Intel(R) Core(TM) i7-3770 3.40GHz
RAM:4.00GB
How can I fix it?
Please advise for me.
Sergey_K_Intel
Could you reproduce the issue with "umc_video_dec_con" application?
Chao_Y_Intel
Please also check if the Intel  media SDK can meet your requirement, which include the hardware accelerator as well?http://software.intel.com/en-us/vcsource/tools/media-sdk
Since IPP sample code is put into legacy,  in the new feature, it may not have much update.
Chao
Atsushi_S_
Hello, Sergey. Thank you for your reply.
I tested with "simple_player.exe" for 3hours and checked it with Performance Monitor.
I think memory leak happen.
I attached print screen image of Performance Monitor.
It's leak little, but our viewing software exectute long time and use many UMC::H264VideoDecoder same time.
So, viewing software will hung up for 2 day.
Please advise to me.
Thank you.
Atsushi_S_
Hello, Chao. Thank you for your reply.
I alerady investgate Media Sdk, but this time, I must use Inte IPP.
Media Sdk is next step.
Thank you.
Atsushi_S_
Hello. Sergey.
I tried to test with "umc_video_dec_con.exe" and check memory with Performance Monitor.
I attached print screen of result.
I think it also happen memory leak.
Please check it.
Thank you.
Sergey_K_Intel
We would like to reproduce this. Could you tell how to get the same results as you did?
What stream to feed to umc_dec_con? Any H.264 stream?
Atsushi_S_
I make file of H.264 Video Encode stream of 4 hours.
That's file is H.264 Pure Video  and include AU Delimitter.
Encoder's setting is
Resolution : 720x480
Bitrate: 2M
Profile: Main Profile
Frame Rate:30fps
Picture type: I-Frame, B-Frame, P-Frame
GOP Size: 15
GOP Structure:3
and I execute umc_video_dec_con.exe like "umc_video_dec_con.exe -i filename -t 3 -f yv12"
That's result is
Stream type: H264PV
Track 0:H264 YUV420 (8,8,8) TFF 720x480 (1:1) 29.97fps P77 L30 *
Output data: YV12 (8,8,8) TFF 720x480 (1:1)
Progress: 1000.00%; Frames: 502429; FPS: 1609.28
Statistic (502429 frames):
    Overall:    530.68 sec; 946.76 fps
    Decoding: 480.76 sec: 1045.08 fps
    Conversion: 39.70 sec; 12654.67fps
     Decoded:    260459193600 bytes
     Avg. bitrate: 1996590 bps
That's all.
Please check it.
Thank you.
