H.264 SelectSplitter fails...
detlef_stralaudynami
on some german public tv channels. The analyse of the stream does never end. I don't know why, but i can play it in vlc and other players. I use IPP 7.0.7 and UMC 7.0.7.
Detlef
SnapShot.mpeg
Chao_Y_Intel
Detlef,
Which splitter are you using for this video? H.264 splitter in the UMC sample code is only used to decoded the raw H.264 file.
I also tried to decode the attached file with some tools, like FFMEG. It reported it stream include some error. Do you notice it as well?
Chao
THX for your response. What should i say, "ZDF" is the second TV provider under public law in germany and they said, all is sended h.264 conform.
Other streams, like SKY HD works well.
Maybe it is possible to make the UMC::Splitter a little bit more "flexible" in the next release.
If you need more test cases, i will send it.
Detlef
