H264 Auto key frame controls method
Elston
I have set the H264 encoder to generate the IFrames automatically. But after debugging I see that internally the key frame control method is set to interval with the interval set to 250.
I thought auto should really have generated an IFrame whenever required. Am I missing something here? If so can someone point me out to the right way of setting the Auto mode.
Elston
Chao_Y_Intel
Elston,
How did you set the key frame control? If it is automatically set the key frame, it needs to set the encoding parameters as follows before init the encoder():
key_frame_controls.method=0;
key_frame_controls.interval=0;
Also which version of Intel IPP are you using?
Chao
Elston
I am using IPP 6. I am settingkey_frame_controls.method = UMC::H264_KFCM_AUTO and not setting any value for interval.
However on debuging I see that it internally setskey_frame_controls.method = UMC::H264_KFCM_INTERVALandkey_frame_controls.interval = 250
Chao_Y_Intel
Could you have a check on the new 7.0 release? I think this feature was added in the new release.
Chao
