H264 artifacts in decoded stream.
gord
We are using the umc_h264_dec_con sample to decode. We have one stream that produces garbage randomly.
I have attached the file that demonstrates this. (The stream is from an Arecont IP camera). Areconts application decodes and displays the H264 stream correctly, so it would seem that there is something wrong the IPP decoder.
Vladimir_Dudnik
Thanks for providing us with test data. What version of IPP do you use?
Vladimir
Ying_H_Intel
Hi Gord,
Wecan reproduce the problem. There arerandom garbages at the bottom of frames. But I found that stream is corrupted (reference decoder meet bitstream errors too). So, I guessumc h264codecrobustness algorithm is poor and should be improved to eliminate random garbage. I have esclated the request tothe sampledevelopers. I willkeep you update ifwe have any news for this.
Ying
