6847 Discussions
Help: Image Quality Problem when resize an image with ippiResizeSqrPixel_32f_C1R function
kangscut
Figure1. Original image Figure2. resized with Lanczos method
I am using Ipp6.0 version, The input and output image(Dicom image) only have one channel, 16bits per pixel. After Res ize with ippiResizeSqrPixel_32f_C1R function, the interpolated image obviously has much more noise than the original image with IPPI_INTER_LANCZOS, IPPI_INTER_CUBIC, IPPI_INTER_CUBIC2P_CATMULLROM. Especially for Lanczos method.
Some parameters for my test: original image size: 512*512; ResizeFactor=2.0; pfImageIn, pfImageOut is a memory block allocated with new operator
Here is part of my code, waiting for your help:
int iColSrc = iImgCol; // original image's width
int iLinSrc = iImgLin; // original image's height
int iColDst = short((float)iColSrc * fResizeCol) ; // dest image's width
int iLinDst = short((float)iLinSrc * fResizeLin) ; // dest image's height
IppiSize size = {iColSrc, iLinSrc};
IppiRect srect = { 0, 0, iColSrc, iLinSrc };
Ipp iRect drect = { 0, 0, iColDst, iLinDst };
Ipp8u *buf;
int bufsize;
//calculation of work buffer size
ippStatus = ippiResizeGetBufSize(srect,drect,1,iInterType,&bufsize);
buf = ippsM alloc_8u(bufsize);
if(NULL==buf)
iErrType = MemoryErr;
return false;
// resize m_pfImageIn
ippStatus = ippiResizeSqrPixel_32f_C1R(pfImageIn, size, iColSrc*(int)(siz eof(Ipp32f)), srect,
pfImageOut, iColDst*(int)(sizeof(Ipp32f)), drect,
fResizeCol, fResizeLin, 0, 0, iInterType, buf);
Vladimir_Dudnik
somehow I do not see your images. Also wondering if you can test this with the latest version which is IPP 6.1 update 4?
Vladimir
