6847 Discussions
How to change Default Screen Position (0,0) when run Simple_Player
dzhou_tac
I want to change the default window position (0,0) to some other lacation, what needs to be changed. rDispRect structure left, top... seems has some problem. If I change lef.t .top and bottom, right, to shift (100, 100), (add all member with 100) then the window shrink 100 (left top moved 100, but bottom right remains the same) If I add big enough number, then it changed the location. So I might need to change something else?
thanks,
david
