6823 Discussions
How to correctly use ippiRotate to get expected result
Xiang_Ma
I need to rotate an imagewhich is 16 bitswith a w/h. After rotation, the new rotated image should have bigger size. say (w+ deltaW)/(h+deltaH).
I found it only work correctly for some size images (say 640x512), but not correct for other size image- image is distorted a lot.
Following is my code. Thanks very much for any help to find what is wrong on this code.
void Rotate(
unsigned short *pInputImage,
int m_iImage_width,
int m_iImage_height,
double angle,
bool bKeepOrigiImageSize,
unsigned short *& pRotatedImage, // rotated image
int & rImage_Width, // rotated image width
int &rImage_Height, // rotated image height
int iInterpolationMethod)
double xShift= 0;
double yShift= 0;
double xCenterSrc = m_iImage_width/2.0;
double yCenterSrc = m_iImage_height/2.0;
double bound[2][2];
IppStatus Status;
int srcStep_16u= 0;
int desStep_16u =0;
IppiSize srcSize = { m_iImage_width, m_iImage_height };
IppiRect srcRect = { 0, 0, m_iImage_width, m_iImage_height };
// find rotate shift
Status = ippiGetRotateShift ( xCenterSrc, yCenterSrc, angle, &xShift, &yShift );
// find rotated boundary box
Status = ippiGetRotateBound ( srcRect, bound, angle, xShift, yShift);
double xTotalShift = xShift;
double yTotalShift = yShift;
if ( !bKeepOrigiImageSize)
rImage_Width = bound[1][0] - bound[0][0]+1;
rImage_Height = bound[1][1] - bound[0][1]+1;
xTotalShift = xTotalShift - bound[0][0];
yTotalShift = yTotalShift - bound[0][1];
else
rImage_Width = m_iImage_width;
rImage_Height = m_iImage_height;
IppiRect dstRect = { 0,0, rImage_Width , rImage_Height };
IppiSize dstSize = { rImage_Width, rImage_Height};
// allocate memory
Ipp16u *pIpp16Images = ippiMalloc_16u_C1(m_iImage_width, m_iImage_height, &srcStep_16u);
// Where I should use srcStep_16u?
Ipp16u *pIpp16Imaged = ippiMalloc_16u_C1(rImage_Width , rImage_Height, &desStep_16u);
// Where I should use desStep_16u?
Status = ippiSet_16u_C1R(0, pIpp16Imaged, desStep_16u, dstSize);
// should I use memcpy or ippiCopy_16u_C1R?
memcpy(pIpp16Images,pInputImage,m_iImage_width* m_iImage_height*sizeof(Ipp16u));
Status = ippiRotate_16u_C1R(pIpp16Images, srcSize, 2*m_iImage_width, srcRect, pIpp16Imaged, 2*(rImage_Width), dstRect, angle, xTotalShift, yTotalShift, iInterpolationMethod);
pRotatedImage = new unsigned short[rImage_Width * rImage_Height];
memcpy(pRotatedImage,pIpp16Imaged,rImage_Width * rImage_Height*sizeof(unsigned short));
ippiFree(pIpp16Images);
ippiFree(pIpp16Imaged);
Chao_Y_Intel
The image step does not look correct in the code.
Change:
to the followngs:
ippiCopy_16u_C1R( pInputImage, m_iImage_width*sizeof(Ipp16u), pIpp16Images, srcStep_16u, srcSize);
Status = ippiRotate_16u_C1R(pIpp16Images, srcSize, srcStep_16u, srcRect, pIpp16Imaged, desStep_16u, dstRect, angle, xTotalShift, yTotalShift, iInterpolationMethod);
ippiCopy_16u_C1R( pIpp16Imaged, desStep_16u, pRotatedImage, rImage_Width*sizeof(unsigned short), dstSize);
The article may provide more information on this problem.
http://software.intel.com/sites/products/documentation/hpc/ipp/ippi/ippi_ch2/ch2_regions_of_interest_in_intel_ipp.html
Chao
