How to force IVOP frame in H264 video encoder
mazhurin1
I am encoding video using h264 encoder.
Sometimes I need to force encoder to generate an IVOP frame.
All I found so far is some comments inumc_h264_pub.h:
typedef Ipp32s H264_Key_Frame_Control_Method;
// These methods control how often key frames are generated.
// Note that, regardless which of these methods is used, additional
// interfaces exist that allow a key frame to be requested on demand.
Am I missing something?
Anton
Chao_Y_Intel
There is no direct support in the encoder part. You can look at the code of the following function:
EnumPicCodType H264ENC_MAKE_NAME(H264CoreEncoder_DetermineFrameType)(
void* state,
Ipp32s)
and change the code to the application needs.
Chao
mazhurin1
Thanks a lot!
Anton
