6845 Discussions
How to get each encoded frame data from bitstream file?
Jie_H_Intel
I just get the video bit stream file using umc_enc_con.exe and I want to decode this bit stream directly. But how can I get each encoded frame data from the pure video bit stream? Shall I need to add some bits signs to separate each frame stream in the encoder part? I just want to check out the results of decoder. Pls give me some advice on this case.
Thank you && Best Regards,
Grace
Vladimir_Dudnik
Hi Grace,
why do you need encoded bitstream for each separate frame? You can decode whole bitstream and do comparison against reference frame by frame.
Vladimir
