6846 Discussions
How to prevent ICC from mangling function names in C code that uses IPP?
augustojd
Hi all,
When I compile the following source code, it appears that Intel C++ Compiler is mangling "ippsDESBufferSize" regardless of the "/TC" option. __cplusplus is also not defined.
#include "stdio.h"
#include "ippCP.h"
int WinMainCRTStartup() {
int result, size;
result = (int) ippsDESBufferSize(&size);
printf("Result: %d, size: %d ", result, size);
#ifdef __cplusplus
printf("def __cplusplus ");
#endif
return 0;
When I try to link the object (compiled with ICC) of this source file with ippCP_XSC41PPC_r.lib in order to generate the executable, I receive this error from the linker:
Compiling...
main.c
Linking...
main.obj : error LNK2001: unresolved external symbol _ippsDESBufferSize@4
ARMV4Rel/tstajd.exe : fatal error LNK1120: 1 unresolved externals
If I use Microsoft eMbedded Visual C++ to compile the source file, the executable is generated without any errors. The same applies to gcc in Linux.
Any ideas of how I can solve this problem?
Environment:
* Microsoft Windows 2000 Professional
* Microsoft eMbedded Visual C++ 4
* PocketPC 2003
* Intel XScale C++ Compiler 1.1
Follow up (May 26th):
From ippdefs.h:
#if defined( _WIN32 ) || defined ( _WIN64 )
#define __STDCALL __stdcall
#define __CDECL __cdecl
#define __INT64 __int64
#define __UINT64 unsigned __int64
#else
#define __STDCALL
#define __CDECL
#define __INT64 long long
#define __UINT64 unsigned long long
#endif
#if !defined( IPPAPI )
#if defined( IPP_W32DLL ) && (defined( _WIN32 ) || defined( _WIN64 ))
#if defined( _MSC_VER ) || defined( __ICL )
#define IPPAPI( type,name,arg )
extern __declspec(dllimport) type __STDCALL name arg;
#else
#define IPPAPI( type,name,arg ) extern type __STDCALL name arg;
#endif
#else
#endif
#endif
Intel C++ Compiler seems to define _WIN32 when compiling code for WinCE on ARM/XScale and therefore all functions are declared as __stdcall. From http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vccore98/html/_core_adjusting_naming_conventions.asp ,
__cdecl _name Mixed case preserved
__stdcall _name@nn Mixed case preserved
I've dumped the symbols in Intel IPP ippCP_XSC41PPC_r.lib for ARM/XScale and none of them have the __stdcall naming convention, so I suppose they were compiled with __cdecl. Would this be a issue in ippdefs.h (__cdecl should be default for WinCE) or in Intel C++ Compiler (_WIN32 shouldn't be defined for WinCE -- only _W32_WCE should be defined)?
Message Edited by augustojd on 05-26-2005 06:32 AM
Vladimir_Dudnik
IPP functions should be declared as STDCALL. If it is not so please submit yuor issue report to IPP Technical Support (premier.intel.com)
Vladimir
