How to set mpeg4 encoder GOP length?
atvan
Is there a way to set GOP length for mpeg4 encoder? For example, one I frame for every 30 frames.
ezcom
Vladimir_Dudnik
I think that should be accessible through PAR file. Did you saw an example PAR file with audio-video-codecs sample?
Vladimir
Chao_Y_Intel
Hi ezcom,
Coudld you check if the sample par file \audio-video-codecs\application\umc_video_enc_con\mpeg4.par
the following paramter may work for you:
100 // max I-VOP distance
Chao
