How to use codecs G729 and G729ab?
garakh
Hello.
I've downloaded IPP for Windows (with Samples) and got the following troubles:
there is no sample how to use G729 and G729ab.
Does anybody know where I can find info about using those codecs, and it would be great, if it will be with code-samples.
Thanx.
Vladimir_Dudnik
Hello, are you saying that IPP Speech codec sample does not contains G.729 codec and simple application?
Vladimir
Vyacheslav_Baranniko
New Contributor II
Hello
Please, tryone of the speech-codecs sample: ./application/usc_speech_codec.
Readme.htm with howto'sprovided there in also.
It supports G729, G729ab and many other.
Vyacheslav
garakh
What the command line should I use for example that codes wave-file that I can codes this file by codecs G729, G279ab???
