How to use the DV encoding pipeline.
viper190
Hallo everybody,
I use the IPP libs the first time and i have problems
one a project i work on.
I have to write a DV25 Decoder and i am not able to
perform the first step.
With ippiInitAllocHuffmanTable_DV_32u i want to setup the
VLC encoding table but I have problems by setting it up.
Is somewhere an example where I can take a look on??
Greetings
Vladimir_Dudnik
Did you look at IPP samples?
IPP has many code samples, including media sample which is set of codecs, including H.261, H.263, H.264, MPEG2, MPEG4, DV and couple application which use them to playbackmedia streams in different formats.
Vladimir
