IPP 5.3.4 Echo Canceller Update
jhr
In IPP 5.3.4 release note you can read this about the echo canceller:
. Improved Echo cancellation issues in Speech coding function and Sample
Unfortunately there is no sample package for 5.3.4, the closest I can get is w_ipp-samples_p_5.3.101.zip which has no changes in the echo canceller code.
Where can I get the samples which contains this update ?
Ivan_Ryzhachkin__Int
Quoting - jhr
IPP AEC essentialy improved starting6. release.
regards,
Ivan
jhr
regards,
Ivan
I understand, but I can't update to 6.x for now.
Since there is an improvement in 5.3.4 as stated in the release note I would like to be able to get it.
Can you get more information about this AEC fixed issues in 5.3.4 ?
Regards.
Quoting - jhr
Regards.
Unfortunately I failedto find 5.3.4 package. 5.3.101 has integer implementationwhereas 6.> is float. => Better NR,NLP, NLMS.
regards,
Ivan
