6825 Discussions
IPP 7.0 Beta UIC crashes for wdp (JPEG XR) output
Goran_N
HI,
I am trying to run the UIC sample app to create a jpeg XR image. I am using the "uic_test_image.jpg" test image.
I use this command-line arguments:
uic_transcoder_con.exe -i=uic_test_image.jpg -o=out.wdp
but the app crashes (memory access violation).
I am using Win7 64-bit.
Any ideas how to fix this? Thanks.
Vladimir_Dudnik
Thanks for interest to UIC and reporting on issue. We will check what might be a reason of that issue and will update you on that. I assume you use precompiled UIC application, is that correct?
Vladimir
Goran_N
I tried both precompiled and the one I built and I get the same result.
Vladimir_Dudnik
Thanks, do you see the same issue with 32-bit version of UIC JPEG-XR codec?
Vladimir
Goran_N
I only have only downloaded IPP for x64, so I haven't tried Win32.
Vladimir_Dudnik
Ok, thanks. Anyway we will pay attention to issue you reported and come back to you shortly.
Vladimir
