Robert,
thanks for your report. We will check this problem.
Chao
I've tried to reproduce your problem and all ok on my MacOS X 10.6.1 systemwith IPP 7.0 gold update1 and update2:
$ otool -L libippcore-7.0.dylib
libippcore-7.0.dylib:
libippcore-7.0.dylib (compatibility version 7.0.0, current version 7.0.0)
libiomp5.dylib (compatibility version 5.0.0, current version 5.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 111.1.1)
/usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version 1.0.0)
$ install_name_tool -change libiomp5.dylib /Library/Frameworks/Intel_IPP.framework/Libraries/libiomp5.dylib libippcore-7.0.dylib
/Library/Frameworks/Intel_IPP.framework/Libraries/libiomp5.dylib (compatibility version 5.0.0, current version 5.0.0)
$ libtool -V
Apple Computer, Inc. version cctools-750
$ sw_vers
ProductName: Mac OS X
ProductVersion: 10.6.1
Please compare your version of cctools with mine and could you give me your version of cctools?
Once I've met the problem with cctools and upgrading them helps me.
Pavel
I've tried to reproduce your issue on my MacOS X 10.6.1 with XCode 3.2 and all ok for IPP 7.0 update1 and update2:
$ libtool -V
$ sw_vers
What is your version of cctools? Once I've meta problem with cctools and upgrating them helps me.
Pavel
Last login: Mon Mar 7 16:29:37 on ttys004
rbell:~ bertie$ libtool -V
Apple Computer, Inc. version cctools-782
ProductVersion: 10.6.6
BuildVersion: 10J567
Also, my Xcode versions is:
Version 3.2.3
64-bit
Component versions
Xcode IDE: 1688.0
Xcode Core: 1691.0
ToolSupport: 1591.0
Just to make sure, I ran the same attemp again since I have probably updated my machine since the post. I usually keep my machines quite up to date. Here is the latest output:
Last login: Tue Mar 8 05:11:21 on ttys005
rbell:~ bertie$ mkdir ipp_test
rbell:~ bertie$ cd ipp_test/
rbell:ipp_test bertie$ ls -la
total 0
drwxr-xr-x 2 bertie staff 68 Mar 8 05:17 .
drwxr-xr-x+ 71 bertie staff 2414 Mar 8 05:17 ..
rbell:ipp_test bertie$ cp /opt/intel/ipp/lib/libippcore-7.0.dylib .
total 208
drwxr-xr-x 3 bertie staff 102 Mar 8 05:18 .
-rwxr-xr-x 1 bertie staff 105096 Mar 8 05:18 libippcore-7.0.dylib
rbell:ipp_test bertie$ otool -L libippcore-7.0.dylib
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 111.1.3)
rbell:ipp_test bertie$ install_name_tool -change libiomp5.dylib /Library/Frameworks/Intel_IPP.framework/Libraries/libiomp5.dylib libippcore-7.0.dylib
install_name_tool: for architecture i386 object: libippcore-7.0.dylib malformed object (section contents at offset 0 with a size of 172, overlaps Mach-O headers at offset 0 with a size of 1336)
I'm going to investigate it for several days, please wait a little
Pavel
thanks for waiting. I've found a problem in IPP. I'll try to fix it in IPP 7.0 update4.
Thanks for your report, Pavel
I found the root of case it will be fixed in IPP 7.0.4 gold
Best regarg, Pavel
