IPP H.264 Encoder compress a frame
mdsaku
Hi Experts,
I IPP H.264 encoder, there is a function " Status H264ENC_MAKE_NAME(H264CoreEncoder_CompressFrame)". May I know is this function compress only one frame or all of the frames. I did not find any for loop for encoding each frame.
Basically, I used JM previously. May I know which function of IPP H.264 is similar to main () of JM?
Mohammed
Ying_H_Intel
Hi Mohammed,
There isa doc in the sample:audio-video-codecs\doc\umc-manual.pdf, it lists that
H.264Encoder Class Methods: GetFrame()Passes a frame to encode and gets an encoded
frame.
You may refere to it or refer thesamplecodein the article: Getting Started with Intel IPP Unified Media Classes Sample
Ying H.
