IPP MP3 usage code sample
reuvenm
I am trying to write a simple MP3 player while using the IPP MP3 Audio Decoder lib.
Can any one pinpoint on some usage example?
Thanks, Reuven
Vladimir_Dudnik
sure, we have sample how to use all these codecs we develop. Did you take a look on IPP Media Sample? It contains simple_player application, which able to playback not only video streams but also just an audio streams, like mp3 files
Vladimir
reuvenm
Thanks for the information, I have downloaded the code sample, however the used API seams to be deferent from the IPP version that I am using (2.0 Beta).
In case thatcode sample is available, which uses thesuitable API (2.0 Beta), I will be glad to get a pointer to it.
The upgrading of the IPP version is not an option due to the used platform and version of ARM CPU.
Thanks a lot, Reuven
Vladimir_Dudnik
we did not port new sample to this old API
Vladimir
reuvenm
Sorry for the nagging, but is there an old example available???
Reuven
Vladimir_Dudnik
Unfortunately, old example code is not available (we do not deliver old versions of products after their support was canceled).
Vladimir
