6820 Discussions
IPP MPEG2 encoder (IPP version 5.1) causes whole server reboot
alienbat
Hi all:
We've been running an application which utilizes IPP (5.1) MPEG2 encoder on the intel server system SR2520SAX
(motherboard: S5000VSA, CPU: 2.5GHZ quad core x 2, 45nm). The server will reboot (no blue screen or crash, just reboot straight away) after a short period of time.
We tested this application but using another non-IPP MPEG2 encoder engine and it runs just fine. And if we take a way one CPU and make server run on only 1 CPU, using the IPP encoder, it's also OK. And it's good on other 1 CPU workstations.
Does any one know something about this issue? Thanks!
Cheers
Alienbat
Ying_S_Intel
How did you build Intel IPP sample, do you use static library or dynamic library from version 5.1?
I would recommend to get the latest version to check this issue again:
the latest product release: 5.3 update 3 (http://www.intel.com/software/products/ipp)
or the latest IPP 6.0 beta version (http://www.intel.com/software/products/ipp/beta)
In both versions mentioned above, threaded static libraries have been added, so you could use threaded static libraires for multi-core systems.
When you recheck this issue with newer version, please ensure upgrade both libraires and sample.
additionally, there were a lot improvements on umc manual since version 5.1 , you may check this new manual located in directory ipp-samplesaudio-video-codecsdoc.You can check the part of vidoe encoding and see how these parameters are set up..
Please let us know how it works with new version.
Ying
