IPP/OPENCV Performance
m_forster
I'm facing the problem that my OPENCV test program ist much slower with the IPP modules loaded than without. I have no clue what's going on there.
I check the modules using getModuleInfo() and it seems to be alright.
Any suggestions ??
Thx, MFO
Vladimir_Dudnik
Only one suggestion - could you please provide detailed info what kind of platform do you use (processor, OS, compiler), what version of IPP and OpenCV libraries do you use. What your test program do exactly, which functions does it call, how many data does it process? It also would be nice if you can attach the test sample here.
Vladimir
m_forster
Sure ...
IPP 5.2 and OPENCV 1.0.0
CPU: Intel Core 2 Quad
OS: Fedora Core 7
Compiler: gcc4.2
The sample looks like this:
#include
#include
#include
#include "FrameworkTime.h"
#include "boost/shared_ptr.hpp"
using boost::shared_ptr;
#include
int main()
FrameworkTime::TimeStamp time1;
FrameworkTime::TimeStamp time2;
const char* opencv_libraries = 0;
const char* addon_modules = 0;
cvGetModuleInfo( 0, &opencv_libraries, &addon_modules );
printf( "OpenCV: %s Add-on Modules: %s ", opencv_libraries, addon_modules );
IplImage* img = cvLoadImage("20050211142625000.jpg", CV_LOAD_IMAGE_GRAYSCALE);
IplImage* sobel = cvCreateImage(cvSize(img->width, img->height), 8, 1);
IplImage* canny = cvCreateImage(cvSize(img->width, img->height), 8, 1);
//cvNamedWindow("original",1);
cvNamedWindow("sobel",1);
cvNamedWindow("canny",1);
time1.setCurrentTime();
cvSobel(img, sobel, 1, 1);
cvCanny(img, canny, 50.0, 100.0);
time2.setCurrentTime();
std::cout << "Algorithm took " << (time2-time1) << "usec" << std::endl;
//cvShowImage("original",img);
cvShowImage("sobel",sobel);
cvShowImage("canny",canny);
cvWaitKey(20000);
cvReleaseImage(&img);
cvReleaseImage(&sobel);
cvReleaseImage(&canny);
cvDestroyWindow("test");
return 0;
aneeska
Hi Vladimir,
I have tried using openCV and IPP together. But I am not getting any performance boost at all. I am attaching my system info as was reported by one of the tools that came with IPP - ps_ippcv.
CPU Intel Pentium 4 processor with SSE3 2x2800 MHz L1=8/12K L2=1024K
OS Linux
Computer localhost.localdomain
Library libippcvt7.so.5.3 5.3 Update 2 build 85.21 02/17/08
IPP -> intel-ipp53068_ia32-5.3p-068
openCV -> opencv-1.0.0-3.fc7
The test program I ran was the sample facedetection program that comes with openCV. I ran facedetection on live video which is captured by a web cam whose pics are of size 360 x 270 pixels. Approximately processing each frame takes 100 ms with and with out IPP. (I used 'cvGetModuleInfo' to make sure that IPP is available to openCV).
I am waiting for your suggestions.
-- anees
Vladimir_Dudnik
TheIPP face detection functions were designed to utilize threading and so there is some difference in approach which used in OpenCV. There are two questions actually,
1. New IPP functions are required to cover OpenCV usage model
2. Experience is needed to use IPP face detection functions, you may take a look on IPP face detection sample. Its performance depends on set of parameters which should reflect expected face size. When parameters are choosen appropriately there is noticeable improvement in performance.
Vladimir
