IPP RT
gcadet
I have tried to use the trial version of RT with IPP 5.2.
I can build the kdtree and initialize the intersection context with kdtree node, tri accel and bounding box pointers. But when I want to launch a bundle of rays (or just one ray) with ipprIntersectEyeSO_32f(...) then I get a memory access error. Perhaps I have done something wrong with arrays of pointers ! I don't know.
Could you please give me a simple as possible sample of code using this function. A database composed of 2 triangles and tracing 2 rays towards these triangle centers is enough for me !
Gilles Cadet
Vladimir_Dudnik
Hi Gilles,
did you take a look on IPP 3DViewer example?
Vladimir
gcadet
Thanks Vladimir,
My error was in array allocation for directions and hits vectors. I have done AOS instead of SOA...
It works fine now. I will play with a little bit now.
Gilles
Vladimir_Dudnik
Hi Gilles,
just in case, our expert has created example of use for that function, you can find it in attachment.
Vladimir
