IPP Runtime - Uninstall
sebarnolds
Hi.
I am testing my installation program for software I am developping. My software is quite complex and it requires to create a new Windows account before proceeding to installation. Then, the user must logon to this new user account and continue the installation process (which includes IPP RTI 4.1). The problem is that it is impossible to uninstall IPP RTI 4.1 later from anywhere else than this user. The uninstall data is stored in the registry (HK_LOCAL_MACHINE) but only the account used for the installation shows it. Is there any way to be able to uninstall IPP RTI from any user account ?
Moreover, it seems the key isn't cleared from the registry if I uninstall it ?
Thanks for your help.
Vladimir_Dudnik
thanks for reporting about this issue, could you please also submit this into Intel Premier Support, so we can analize and try to help you?
Vladimir
sebarnolds
Hello.
Just a correction regarding my original post. My last remarks is not correct. I worked on the problem these days and I always removed the uninstall key from the registry (dunno why it didn't once).
I managed to get rid of my problem by using a small utility which allowed me to run the uninstall program using another account that the one currently in use.
Thanks anyway.
Vladimir_Dudnik
Ok, thank you for letting us know
Vladimir
