IPP SBR encoding problem
evgeny777
Hi, all!
I'm trying to make AAC SBR encoding work, but cannot do this.
The AAC-LC works properly, but with SBR I get strange artifacts, when using both floating point and
integer encoders. Artifacts are different in each case. In case of floating poing encoder artifacts sound
like clicks, in case of integer encoder there are some high pitch noises.
Has anyone come across such problem?
Naveen_G_Intel
Just I found expert suggestion on similar issue, refre http://software.intel.com/en-us/forums/showpost.php?p=92544
Naveen Gv
evgeny777
Thanks!
I saw this post before. As far as I understood it is about configuring the IPP decoder, not encoder
I do not use IPP decoder. I use QuickTime player to decode AAC file and play audio
