IPP Samples Build Options
transcoding
Hi all,
Is it possible to speed up the build of IPP samples by compiling only the modified modules?
Thank you,
transcoding
Sorry, I forgot to mention that I'm using audio-video-codecs in IPP samples and that I'm building using GCC4.
Quoting - transcoding
Hi all,
Thank you,
Harri
A partial solution is to comment the lines in build32.sh that cleans and removes all builded object code and applications.
I.e.
#[ -d ${ROOT_DIR} ] && rm -rf ${ROOT_DIR}
and
#${MAKE} ARCH=${SAMPLE_ARCH} ROOT_BIN_DIR=${ROOT_DIR} clean > /dev/null 2>&1
transcoding
Thanks!
I though of this solution, but I'm looking for more sophisticated manner to do the job ;-) Maybe!
