6838 Discussions
IPP XScale compile error - "uses VFP instructions"
Intel_C_Intel
When I try to compile one of the example applications (e.g., 'Filtering') with IPP v4.0 for Xscale, I receive errors of the following sort (during linking):
/usr/local/ipp/ippwmmx40b/lib/ippSP_WMMX40BLNX_r.a(ssrand.o) uses VFP instructions, whereas .//Filtering does not
Presumably, the Makefile provided has taken care of the correct C-flag options.
I did a Google search (i.e. "uses VFP instructions" or gcc vfp flag), and there was some discussion of this issue. However, I cannot still decipher what the underlying problem is, nor how to solve it.
It appears to be a difference between object files I compile, and the way the IPP libraries were compiled. One was VFP (vector floating point) and the other way was FPA (floating point accelerate?).
I've tried a bunch of compilation flags that may be related (e.g., -mhard-float vs. -msoft-float, etc.), but nothing seems to change.
Perhaps the IPP v4.0 libraries need to be recompiled with different flags, or the tool-chain I have is not compatible (but it was provided by Intel). I need to know either way what I can do to resolve this. Thanks,
Dean
Intel_C_Intel
Hi Dean,
Yes, you need to use the right version of toolchain. For example, for IPP v3.0 you need arm-linux-gcc v2.95, but for IPP v4.0beta you need arm-linux-gcc v3.21.
Hope it helps.
What IPP samples you are interested? What do you think about IPP functionality? Does it meet your expectations?
Vladimir
Intel_C_Intel
Thanks for replying. However I "do" have arm-linux-gcc v3.21 running, so it's not that.
Dean
jsmerritt
I have run into the same problem where IPP 4.1 uses VFP instructions, and contrary to several responses, this CAN NOT be resolved by using an early version of the compiler !
The question seems to be asked frequently with no (valid) answers being returned ...
Thanks, Scott.
Ying_S_Intel
You may check with the toolchain support in IPP 4.1. You can refer to this URL at:
http://www.intel.com/software/products/ipp/sysreq.htm
If you think this is an issue in Intel IPP, please submit an issue via Intel Premier Support.
Ying S
Intel IPP
jsmerritt
For the benefit of other "Linux GCC IPP 4.1 for PCA" users:
- GCC 4.0 (as yet unreleased) is reported to have VFP support
- For additional intellectual stimulation :) you can attempt to build a GCC 3.3.x toolchain with VFP support by including additional patches (search http://sources.redhat.com/ml/crossgcc for details)
- Since the Intel IPP libraries for PCA do not use floating point, you may find it easier to modify the e-flags field in ELF header on each of the object files in the Intel library to report something other than VFP ;) (Intel Premier Support may be able to provide a utility program ...)
Best regards, Scott.
