IPP black/white threshold (like iplThreshold)
sdl
I'm currently investigating and benchmarking IPP as an upgrade to IPL and noticed that a straightforward threshold function is missing.
I'm looking for a threshold function that sets pixels either to the maximum value (if higher that the threshold) or to the minimum value (if lower). So for a 8-bit image, pixels will be either set to 255 or 0 (like the IPL function iplThreshold).
The function closest matching this functionality is Threshold_LTValGTVal, but not all pixels can be changed because you can't have overlapping threshold values and can only use greater or less than, or otherwise I get the error ippStsThresholdErr.
Also, any of the threshold functions with a settable specified value take twice as long as IPL!
Any suggestions on what best to use?
Cheers.
Vladimir_Dudnik
you probably can use sequence of two IPP functions, ippiThreshhold_LTVal and ippiThreshold_GTVal
Vladimir
chris_griffin
pace_sdl,
Was there any followup on the performance issue that you raised here?
I have similar performance concerns about IPP, and I'm seeking to understand why it seems to be slower for some operations (like Set) than regular C++ code doing the same pixel set operation.
Any info helpful,
Chris
Vladimir_Dudnik
Hello Chris,
we constantly work on improving performance of IPP functions. Could you please an example of code which demostrate the case when regular C++ is faster then ippiSet function?
Vladimir
chris_griffin
Hi Vladimir,
I ran across this a few weeks ago. When I get a chance, I'll put together a code sample which times the two against each other. Right now its hard because the calls are buried in my image class methods, and the code which calls them would be hard to share here.
Look back sometime next week, as I'm anxious to understand this.
Thanks!
Chris
Vladimir_Dudnik
Ok, will wait for your case.
Vladimir
