IPP erode issue when eroding entire image
cks2k2
I am trying to apply an erode operation to an entire grayscale image.
Realizing the issues with borders, I use ippiErodeBorderReplicate() but a cross-check with the expected output shows that some pixels (~10) at the top and bottom border are incorrect.
[bash]Ipp8u mask[9] = {0,1,0,1,1,1,0,1,0}; // some random kernel
IppiSize maskSize = {3,3};
IppiPoint anchor = {1,1};
IppiMorphState* morphState = NULL;
IppStatus status;
ippiMorphologyInitAlloc_8u_C1R(dstRoiSize.width, mask, maskSize, anchor, &morphState);
status = ippiErodeBorderReplicate_8u_C1R(pSrc, srcStep, pDst, dstStep, dstRoiSize, ippBorderRepl, morphState);
ippiMorphologyFree(morphState);[/bash]
A copy of the source image is created before the code above is called; source and image have exact same dimensions. ROI has same dimension as source and destination.
Ying_H_Intel
Hello cks2k2, Coudl you please provide the input and output, And if possible, please add the below code // Print the version of ipp being used const IppLibraryVersion* lib = ippiGetLibVersion(); printf("%s %s %d.%d.%d.%d\n", lib->Name, lib->Version,lib->major, lib->minor, lib->majorBuild, lib->build); in your code and and let me know the result? Regards, Ying H.
cks2k2
Hi the output that you requested:
lib name: ippiv8l.lib
version: 5.2.108.410
On IPP 5.2.
Ying_H_Intel
Have you try the latest version?
( geta 30-dayseval version fromIntel Downloads, Registration and Licensing
As you haven't provide the test image,Itried the sample 8-2
#include
#include
#include "ipp.h"
int main()
IppiMorphState* ppState;
IppiSize roiSize = {5, 5};
Ipp8u pMask[3*3] = {1, 1, 1,1, 0, 1,1, 1, 1};
IppiSize maskSize = {3, 3};
IppiPoint anchor = {1, 1};
Ipp8u pSrc[5*5] = {
1, 2, 4, 1, 2,
5, 1, 2, 1, 2,
1, 2, 1, 2, 1,
2, 1, 5, 1, 2};
int srcStep = 5;
int dstStep = 5;
Ipp8u pDst[5*5];
int dstSize = 5;
IppStatus status;
ippiMorphologyInitAlloc_8u_C1R( roiSize.width, pMask, maskSize, anchor,
&ppState);
status = ippiErodeBorderReplicate_8u_C1R( pSrc, srcStep, pDst, dstStep, roiSize,
ippBorderRepl, ppState);
printf ("ippiErodeBorderReplicate return %s\n", ippGetStatusString(status));
ippiMorphologyFree(ppState);
int i=0, j=0;
for ( i=0; i<5; i++)
for (j=0;j<5; j++)
printf("%d \t", pDst[i*5+j]);
printf("\n");
return 0;
I have the below result.
ippiv8-7.0.dll 7.0 build 205.58 7.0.205.1054
ippiErodeBorderReplicate return ippStsNoErr: No error, it's OK
1 1 1 1 1
1 1 1 1 1
1 1 1 1 1
0 0 0 0 0
0 0 0 0 0
Press any key to continue . . .
Please try it and let me know if any result.
Ying H.
cks2k2
I have attached the test image. Kernel is 3x3, with values {1,1,1, 0,1,0, 0,1,0} and anchor {1,1}. (T-kernel).
Ying_H_Intel
Hello Cks2k2,
Could you tell theplace of wrong result you are seeing? And if possible, please try the latest Ipp version?
I print some value of the test image and result image. Theirresultseems ok.
With T mask.
Src:
src[0] [0:9] and src [1][0:9]
103 95 95 102 108 112 112 109 107 108
110 103 104 110 113 113 112 108 108 110
Dst:
dst[0] [0:9] anddst [1][0:9]
95 95 95 95 102 108 109 107 107 107
src[510] [250:259] and src [511][250:259]
(110) 112 114 111 109 111 111 115 106 113 112
(110) 111 113 110 108 109 110 114 105 112 111
dst[510] [250:259] anddst [511][250:259]
111 112 110 108 109 110 107 105 107 111
110 111 109 108 109 110 106 105 106 111
Ying
