IPP in PXA 255
reactgary
I have got a intel PXA 255 development board and I am going to develop
some application on it using IPP.
I am using Linux.
I have install both IPP 3.0 and IPP 4.0
I have try the example in IPP 3.0 and 4.0
When I compile the example in 3.0, it works nice
(the compiler is arm-linux-gcc)
When I compile the example in 4.0, it don't work
It use the compiler (iwmmxt_le-gcc)
I do not have this compiler.
When I try to use arm-linux-gcc compiler to compiler the example
some error occur
My problem is, which compiler should I use for this situtation
Thank you!!
GaRY
reactgary
My introduction..
I am a Computer Engineering Student from HK
Currently making some application on PXA 255
development board with Linux
Vladimir_Dudnik
please look on this post, it contains info about toolchains to be used with IPP v3.0 and IPP v4.0:
Vladimir
