IPP on FreeBsd
igorb
Hi there,
Does anybody have experience of using IPP on FreeBSD?
Thaks.
Igor
Vladimir_Dudnik
we did not test IPP on FreeBSD system, but you can try, probably it should work as we do not use system calls in IPP.
Vladimir
igorb
Vladimir,
Thanks for information. I've built USC application on LINUX and run on FreeBSD 6.x and it worked perfectly. USC Implementation is great - simple to use and USF File format is very flexible. It is very easy to convert RTP payload into USC Format Frames.
Igor
Vladimir_Dudnik
Hi Igor,
thanks a lot for update on this.
Just to clarify, athough we do not test IPP on FreeBSD system, but due to the fact that IPP was designed to minize system call, it can be run on different kind of systems. I remember, several peopletried IPPon on QNX andvxWorks
IPP under QNX
Could you confirm us whether IPP4.1 fit our platform and applications ?non-pic linking model possible?
Vladimir
