IPP on Windows Mobile 5.0
dario_marchese
I'm developing a Windows Mobile 5.0 PDA application. I try to use IPP to compress a audio stream, with G728 coder.
I'm following the example in the documentation, but this istruction:
USC_Fnxs->std.MemAlloc(&pInfo->params, pBanks);
cause a crash of the application. The same code work fine on Windows XP.
Ihave also compiled usc.lib in debug mode, and I found that the error is in a IPP function, not in the C code of the usc library.
VS2005 report "Invalid instruction". Seems that I'm using IPP for the wrong processor...
I'm using IXP4xx: it's the right library? PXA2xx processors are supported? The VS2005 project is setted for armv4i generic processor.
Dario
Vladimir_Dudnik
Hello Dario,
we did not test IPP on Windows Mobile 5.0. Please refer to IPP release notes for the list of supported operating systems.
Vladimir
dario_marchese
The release notes reports compatibility with"IXP4XX Product Line on Windows CE 5.0 for IXP". I suppose: "if Windows CE is supported, maybe also Windows Mobile will be supported". I made a mistake... :)
Onlyone question: is plannedin future a release compatible also with Windows Mobile?
Any way, thank you for the response.
Dario
Vladimir_Dudnik
Hi Dario,
we do not have right now a firm plane to support Windows Mobile in future version of IPP.
Vladimir
