IPP with RTP
gur
In IPP speech examples i found GSM, G.723, G.729 samples for encoding and decoding.
Can i decoding received RTP stream with GSM, G.723 or G.729 payload into Mu-Law or A-law and how can i do it ?!
p.s
I try decoding gsm file encoded by sox (GSM 06.10) but decodergsmfr.exe is crushed.
Message Edited by Gur on 02-16-2005 08:10 AM
Vyacheslav_Baranniko
New Contributor II
Hi, IPP 4.1 speech coding samples does not support RTP stream. They fasioned to demonstrate compliance to spec, i.e a bit-to-bit correspondence with spec test data, so stores a bitstream in formats each spec does specify for testing. Nevertheless, you can modifiy a sample so as to remove conversion into test files and pack an output raw bits after encode function into RTP format. And vice versa unpack a RTP stream and pass a frame bits to decode function with proper frame type marker. Regards Vyacheslav
gur
thanks
Thanks Vyacheslav.
I found function in main encoding thread - apiGSMFREncode() . Thay get bitstream_buf 33 bytes (GSM RTP frame). After encoded file have same size as sox encoded file. But hi do not playing correctly. :(((((
Please mail me if you know that problem on
[email protected]
telefonie
After Strippng the rtp-header (I think you have it already done), oneSolution is: Transfer it in the formatof theReference Testvectorsfor GSMFR and used the demodecoder.
For packet format -pack option at demo decoder. If the demodecoder can decode packet format you must use this option.
To understand the formats (packet and unpacket), you canhave a look atRef2Bits and Bits2Ref of demodecoder files with name *util*.c.
